NapaBavarian
Dually driver 6.9
It has been a long time since I checked in here, hopefully soon I can get my e350 ambulance back together, it needs transmission assembly and a front drive axle, if anyone has one lying around that could come in handy!
I had intended to use a hypermax van turbo, however in thinking this won't be a fast truck, more a lumbering back roads 4x4 camper, headers and a typ4 cam may do the trick with a fresh fuel injection system.
A couple quick advantages, off idle torquestions is improved a bit, back pressure from the turbo slows things down a bit until they get going.
Since it takes fuel to run a turbo this and I won't need the power of a turbo hopefully this would improve cruising mpg a bit and extend range, this thing only has a 55 gallon tank after all...
From the reading I have done it sounds like the pump can be turned up 1-1.5 flats vs 2-3 flats for a turbo, so off the cuff I figured 50% power increase of a turbo.
I'd like to hear any input from folks who have headers.
