Who all can mod a ATS/Factory Ford turbo... cheaply?
Macrobb
North Idaho
Alright, so I'm sure I'm going to get some complaints here, people telling me I shouldn't do this but...
I'm looking for someone who can get me an upgraded compressor wheel(60-1 mod?) for my factory ford turbo setup.
Only... I don't want to go through a full rebuild. I *just* want a "pre-balanced" or "zero-balanced" wheel(*note), and someone who can mod the housing to match. I've got a spare housing I can send off for this project, but don't want to spend the extra money for all the 'upgrades' and rebuild on one of these.
Anyone know who can(and will) do something like this?
Heck, I'm wondering if there's just a basic forged wheel out there that's the right size for some other application, that can be gotten cheap off-the-shelf and just installed... then I'd just need to have someone machine out the housing for the profile.
(*note: Wicked Wheels are balanced like this - individually, and you can slap it straight into the factory housing with no extra balancing or anything. That's exactly what I want. I did it with mine, and it's worked great for the last couple of years.)
Thewespaul
Bulverde, Texas
Rob I’m already working on a diy upgrade like what you’re talking about doing, it won’t require a core charge since it comes with a new backing plate, housing, compressor wheel and rebuild kit to upgrade your stock turbo, with the parts availability being iffy right now and me being slammed with this move it will be awhile before I have them ready, but it’s in the works.
Macrobb
North Idaho
Awesome! Sign me up to the waiting list!
aggiediesel01
Houston, TX
The concern I see with your desire is that the original rotating assembly was likely balanced as a set. If you swap even a component balanced wheel on, the assembly may still be out of balance. The shop I had balance an assembly for me a few weeks ago told me that because of the style of assembly in these turbos they should be balanced as an assembly; whereas the turbos like in the powerstrokes were designed around component balancing.
If you're going to the trouble of breaking it down far enough to swap wheels and a backing plate then just spend a bit more and put new rings on each end and check the bearings and thrust washer/collar. And balance the rotating assembly. Should be able to do that pretty reasonably.
Look at my turbo album for details of what it takes. It's not hard, just a little dirty.
https://www.oilburners.net/media/albums/factory-turbo-ats-093-rebuild.72/
Macrobb
North Idaho
I'm not sure how far I'll go, but I do think I'm just going to go for it. The Wicked Wheel works great(and evidently is well enough balanced), and I never even pulled the exhaust side loose - just got an impact onto the shaft, vice grips on the old wheel and off she came.
One heck of a lot easier than trying to actually remove the turbo from the engine, that's for sure.
That being said... this may require me to actually do that, assuming I have to replace the backing plate...
Speaking of balance on a powerstroke... I'm guessing there's a lot of support in that bearing. I've worked on two trucks, one at 500K miles and one at 230K. Both compressor wheels were... not pretty. The 500K mile one looks like it's been sandblasted, with serious chunks taken out of multiple fins(like 1/8" pieces at the tip). The 230K one has a couple of big divots.
And yet, /somehow/, these turbos are still running, still making plenty of boost.
(We got 283 RWHP out of the 500K mile one at the dyno last year, with just a tuner).
aggiediesel01
Houston, TX
@Macrobb
It's hard to tell the differences from these pictures but the 093 turbine is the first one and the Powerstroke turbine is the second (it's actually KC turbo's s366 upgrade but close enough). The actual shafts are nearly if not totally identical but the turbine wheels are considerably different. Mainly in weight. I didn't weigh the 093 turbine but the other one weighs 544g and I don't remember the 093 being this heavy. Wheel on the PS seems thicker @ 1.450" ~ 37mm and dia. is 2.995" ~ 76mm. I haven't looked at the maps for these turbos in a long time but I'm pretty sure I remember the PS one spins a significant amount slower than the 093. Bearings look to be identical in spacing on the shaft and physical dimensions of the bearings are identical. Oil rings are identical.
093 turbine shaft (this one has 300k+ miles on it)
Powerstroke turbine shaft (KC turbo s366 upgrade)
093 bearing on top, Powerstroke on bottom
093 on left Powerstroke on right.
aggiediesel01
Houston, TX
Thrust bearings are identical in critical dimensions but slightly different in design. I know the other one I have is a 360* upgrade but I've pulled the OE bearing on a PS before and it looks like the 093 one.
typ4
Newberg,OR
You probably should quit screwing around and just send it to me. I need camshafts we need to do some partial trading.
and for what it's worth Justin doesn't do the factory turbo stuff anymore he sends them all to me, and I think I should get first shot at it since I'm the one that started doing it to begin with.
typ4
Newberg,OR
So are you going to put the powerstroke wheel in factory-style turbo?
aggiediesel01
Houston, TX
You received mine cam right? I can't remember when it was shipped but it might have been while you were gone.
typ4
Newberg,OR
typ4
Newberg,OR
It got here the day I left and I threw it in the house on the floor and it's sitting in front of my chair right now.
haven't really felt like doing anything but I've been doing enough I have ten sets of injectors ready to go. 6 customer turbos to finish up and two turbos on the shelf ready to go.
aggiediesel01
Houston, TX
If that's directed at me, no no no. The s366 wheel is for my '97. I did the rebuild on an 093 that's going into my dad's '93. It's a big convoluted circle jerk involving a three engine two truck switch-a-roo that Wes is helping with but I'm not building hybrid turbos, I'll leave that to others that know enough to do it.
