Put a little to much cetane booster in my 6.0 earlier when I filled up. It's white smoking when idling but not when I get on it. Is my truck hurt????????
I would just dilute it with regular diesel as soon as the tank is down some. I dont think you put enough in there to hurt it. The best way to hurt a 6.0 injector is water, run out of diesel, or contaminated oil.
Ken
Ok now I'm begining to think it has nothing to do with that kleen diesel additive I put in it. I've ran one tank through it and put new fuel in and it is still smokin when idling but not when I give it a little or a lot of throttle i can tell a small power loss but nothing major only problem is it is going through antifreeze and water like crazy!!!! I have filled the resevior twice today!!! At one point today it was hard to start. The oil looks fine and it hasn't used any. Somebody tell me what the heck Is wrong with it. It has 106,000 miles on it. And I just bought it I'm very disappointed in it. I'm starting to want my idi back. At least it never tore up no matter what I done to it. Plus it had 328,990 miles when I got rid of it.
I think they had hg issues and it sure sounds like that could be an issue. I think most stud them with gaskets, but I don't follow 6.0's much. I know a couple people that had to replace them at 100,000 or so, both studded the engine at the hg change.
STOP DRIVING IT!
It is most likely a blown EGR cooler. You need to consider changing the EGR cooler and oil cooler now. I just went through this with my 06. If youre going to repair it I highly recomend either deleting the EGR cooler altogether or using a bulletproof diesel or Sinister diesel EGR cooler.
A quick test it to take the degas bottle cap off when cold and start the truck up. Note how much air is coming out of the bottle. Pull the electrical wire from the turbo that controlls the vanes (looks like a solenoid) and see if that air stops or slows. If it does you need an EGR cooler. If nothing changes you might need head gaskets. A blown EGR cooler leads to blown head gaskets. If youre truck is stock this is even more true.
Ken
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
