Thefarmboy21
Ok I have an 87 F-250 I just put a motor in. After all the troubles it's now got a motor from an 83-86 truck that was nice and clean and "low miles" so he said....but I needed one. Anyway after several laps around the hay field behind a tractor I finally got it fired up. It has good oil pressure (like 50's cold) but when you mash the fuel it POURS white smoke (it was dark though, could be greyish) it also seems to lack power. I drove it around the road and it rans fairly well just seemed like it was lacking and hard to take off. ALSO there's always air when I hit the Schrader valve, never a stream of fuel...there used to be a good stream when I was trying to start it by cranking, then it all just quit and I thought my lift pump went bad. But it does run just nothing but air at Schrader. Also it idles a little off...not "bad" just not smooth. At first it would idle way up spontainiously and die, then we bled more air and it would idle up and down some....the more air and it idles ok, just not smooth like it should. Sounds like it's missing. I don't know if it's air causing the smoke or a head gasket. Also could my lift pump be going bad? It's new but WAS giving me a full stream at Schrader and now just air. HELP!!!! these problems are just the motor, has some weird wiring issues too. THANKS!!
