MIDNIGHT RIDER
- Joined
- Sep 29, 2005
- Posts
- 4,666
- Reaction score
- 78
I once went into the auto-parts and told the guy I needed some kind of real good knocker-loose; he handed me a can of "KnockerLoose"-brand penetrant and I about fell over; that was some good stuff at the time, but I haven't seen it in years.
Liquid-Wrench also used to be about the best available.
Since, science has provided us with many specialty penetrants; some work wonders on one type of problem, where others will get the job done in a different situation.
WD-40 has obviously been watered-down; it also will no longer "start" an engine.
Simply due to availibility, I often use PB-Blaster; usually what I do is for several days prior to the project, I will give the bolt/nut/whatever a little squirt as often as I remember to.
Just recently, I replaced my 25-year-old shocks; for several weeks, I had been spraying the threads with PB; those old rusty bolts loosened easily; same with a turbo on a 1989 Cummins that I recently removed.
I can't compare it to the Kroil or the other stuff, as none of that is available in my little mudlick town.
Once this principle is understood and given some thought, then one begins to have a lot less trouble getting stuck stuff loose.
The shock of the differing rates of expansion/contraction is what makes heat work when breaking loose frozen components.
Though I haven't seen one in years, there used to be a tool that black-smiths/torch-men used to concentrate the heat on a bolt-head or whatever.
The tool was a simple copper rod with a handle much like the coil-spring handle of a chipping hammer.
You either put the copper rod in the forge, or simply held it's tip on the bolt-head (or nut), while heating the copper with a torch (or forge).
If possible, the business end was kept higher than the cooler end, such that the heat would travel up the copper and transfer to the bolt.
Once the bolt/nut was a dull red, it was allowed to cool.
When it got cool enough to not burn the oil, penetrant was applied.
The expansion/contraction "broke" the connection and allowed the parts to move again.
If everyone was as generous with anti-sieze as I am, then this conversation would be useless.
When you use heat, the different rates of expansion cause the nut/plug/bolt to "break" the seal it has via rust.
Just heat to dull glow, let it cool...doesn't have to be cool to touch or anything, but the expansion and contraction will break the item free.
