bike-maker
The sterling 10.5 axles are an upgrade over the older 10.25. Brakes work better, parking brake works just as well, and the best part to me is not having to jack the rear end up and adjust the brakes multiple times a year.
Front end, depends on who you talk to. King pin axles will break knuckles when pushed passed their limits, ball joint axles will brake the ball joints instead.
99-04 axle unit bearings are under sized for the job with extra load and/or bigger tires and therefore have a higher failure rate than they should. Plus side is they are fairly cheap, and easy to change.
