I doubt the pistons we use are forged or die cast, they are probably permanent mold low pressure (atmospheric) castings. The most popular alloy is 356 which has a reported melting point of 1280 F. If you have 1100 f at the exhaust manifold where the thermocouple is located , you are flirting with danger, since that does not factor in the yield, which in our engines is considerable , considering the operating cylinder pressures. Especially under turbo load. Yikes.
I have seen enough people report 1100 degrees (but never higher for any amount of time) to believe that that temp is the highest tolerable operating temp you should try to experience. Like the man said, if you have sponsors with money that don't complain, go ahead and run hotter.
For purely educational reasons, it would be interesting to see the results of ultra high EGTs. But not from your truck.
