Wheel studs
RLDSL
Diesel fuel abuser
Arkansas
The books seem to list the F350 and 250 with the 10.25 as having the same hub, does this also include the dually and if so do they all use the same size studs?
i've had a nasty little incident with a bad batch of fastenal bolts to where they are all deciding to fail on one side ( the bolts I used to hold the axle shaft in ) where they got brittle and popped ( yes, they were torqued properly, holes cleaned etc )
Are you talking wheel studs, or axle to hub bolts? No on the former, yes on the later.
RLDSL
Diesel fuel abuser
Arkansas
I figured the the axle to hub bolts would be the same, but I was wondering if the wheel studs would be the same and if the 250/350 hub also fit the dually.
It's quite possible, but I can't confirm that.
