Wheel Bearing Torque Spec
Just curious.
If you said just bled like a normal brake change, I was going to recommend doing again until clear fluid comes out.
I had the same reaction when I did mine. About time to do mine again.
Hydro-idi
Lodi, California
Just curious.
Yes I figured it would be a good idea to just go ahead and do all 4 corners. Wasn't a difficult task by any means and was way past due anyways. Also adjusted rear drums and couldn't be happier with job. I did forget to torque down lug nuts. Beer:30 got in the way so I will plan on getting that done tomorrow.
Yup. World of difference.
Most people don't know (or just don't care) that brake fluid should actually be changed every few years.
And you should only buy small containers of brake fluid. That way you only have open what you'll be using. After the seal is broke, use it quick.
After a month or so of the seal being gone (even if the lid is still on) it'll draw in moisture. Not necessarily shouldn't be used at that point, but can lead to lines rusting.
sassyrel
iowa
That's pretty much how I handle bearing preloads. Spin the wheels until there's a drag on it, then back off a few degrees. Then after a few days of driving (or sooner if I feel issues) I will recheck the torque on the bearings.
This is a good thread.
this is correct.............
