WHATS the correct way to seal a injector?
hesutton
The Anti-Anderson
Bowling Green, KY
Replace the return line cap. But, if you've got one leaking, the others are suspect and I'd do the entire set.
Heath
skintbackfarms
AL
Sealing the body itself. I got one the I have pulled a few time and it seems the it still has some bubbles coming from it.
In2Fords
Lincoln City, Oregon
if your talking about sealing it to the head, Crud will build up over time, there is a injector hole cleaner tool that will scrape it out, then a copper washer and that should be it. I've never heard of it but if your injector itself is actually leaking I would replace it, theres a lot of pressure in here and god knows when it would blow.
