4x4TruckinGirl
"Cowgirl"
I REALLY need to do this to my truck..... lol I'm just afraid I'll mess something up!
So your saying you can take a hose and drop it below the engine where air will pass through and can do away with the CDR valve? Also about putting it into the exhaust pipe I would like more information on this. My CRD is about done, and Id like to know advantages to this and procedure.
In my opinion, even with the road draft tube connected to the Banks type unit, these engines are plagued with not enough crank-case evacuation, thus leading to the all too common oil leaks.
Were I to ever build my old 6.9, I would incorporate vents in the valve-covers, the CDR position, the Banks position, and the oil-fill cap.
Also, I would never drain another turbo into the CDR hole, but weld a tube into the oil-pan for that.
I have seen these engines actually push the dip-stick loose and smoke/vapors puff out for hours after shut-down, hence my belief that they are poorly ventilated.
