What's in your intake?
hesutton
The Anti-Anderson
Bowling Green, KY
Mine has the typical coat of oil residue from the old CDR "lubing" my intake for me.LOL
Heath
FordGuy100
Silverton, OR
What is a road draft tube?
A road draft tube replaces the CDR. The CDR lets the crankcase gases go into the intake to be burned. But a road draft tube just lets the crank case gases exit into the air. If you where to pull the air cleaner on a stock N/A IDI with a CDR, you would see how much oil is in the intake, its a good bit.
Actually you might be surprised. I never cleaned mine either. It just cleans itself thanks to a continuous diet of non-poluted air once you switch to the RDT.
RLDSL
Diesel fuel abuser
Arkansas
so how does an RDT work? what do i have to do to convert it?
It works on the same principal as blowing across the top of a beverage straw to draw the liquid up. Air crossing the top of a tube at a right angle creates a vacuum in the tube . If you eliminate the CDR and take the hose and run it straight down BELOW the lowest point on the truck where it remains in constant air flow while the truck is in motion, the air passing under the truck, will create a vacuum that will 'draw' , hence *road draft* the blowby crankcase gasses out of the crankcase. At idle, they will sit there and waft up around the cab , and if you spend a lot of time in city traffic, better lay in a supply of visene, because your eyes are going to take a beating.
All vehicles used to have this type of breather system, but they went to the closed crankcase systems to burn the blowby gasses to reduce emissions. The closed systems really do reduce emissions, and while many don't like maintaining the systems, the hydrocarbon vapours that are being recirculated into the intake, really are good fuel, so if you go RDT, that's free fuel that you are dumping on the ground. Just one other side of the coin. everything has it's trade offs.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
so agnem, what'd you do to convert yours to the RDT? i may wind up twin turboing the scout and i'll have to eliminate the CDR so better now then later. i even got the valley pan blockoff plug in the gasket kit.
-Jon
discbrks
Columbus, GA
Couldn't you hook up the RDT to the exhaust (past the Y pipe) and let the exhaust pull it out? Just like a crankcase evacuation system for a gasser.
GaryB
