What year did electronics show up?
Frstdiesel
East Texas
Hey guys, what year did electronics show up in the Ford diesel pick ups?
Mine is a 1984 and no electronics.
Jason1377
Arkansas
I have a 1993 n have the go controller n a few other things needed to run the truck that are electrical to then that I think power stroke era like 95ish or later
Cactus Bob
STRAWBERRY, ARIZONA
All Ford 6.9-7.3 IDI's use electronics in the in the charging system
the first few years (83-88ish) of the 6.9 they had a screw-in non electronic glow plug controller but they kept failing and most people upgraded them.
All 7.3 IDI's have electronic glow plug control.
Of course the first computer in our diesels was in 1989 (I think) to control the E4OD transmission.
Macrobb
North Idaho
There's some level of "electronics" even back in the early 80s trucks - alternator regulator, radio, cruise control etc.
If you mean "what was the last year with no electronics required to run the truck", that's 94(IDI + ZF5), or 88(IDI + C6).
That being said, even an E4OD doesn't 'require' electronics to move, but will be stuck in 2nd gear basically.
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
91 (I think) was the last year with mechanical speedo.
Correct
The 91 down have a mechanical speedometer. If it has cruise or an E4OD, there is a VSS that plugs into the transmission/transfer case and is mechanically spun, and the speedometer cable plugs into the other side of the VSS. There is a VSS in the rear differential for the RABS. In 92, everything runs off the differential mounted VSS, which supplies a signal to the PSOM and TECA (if E4OD equipped) to run the speedometer/cruise/E4OD/RABS.
