Gas engines are not as rpm limited. Modern gas engine peak horsepower is higher then a idi governed rpm. This lets them get more air through the engine allowing them to burn more fuel. More air more fuel more HP. Yes torque is great for towing, but spin a engine and use the next lower gear and you will have more torque to the wheels. Another limiting factor is the stanadyne pump cannot fill fast enough past 1400 and limits fuel to the cylinders limiting upper hp. If you ever drove a large industrial gas engine that operated in the same rpm as a diesel you would know what gutless is.
