What is this plastic piece and why is it wet?
Fordsandguns
Fords Rule
Eastland Tx
The absolute best remedy is to remove the whole mess, heater and all, and replace it with a standard IN-and-OUT filter-head that takes a better performing three-dollar filter.
I doubt that wimpy little heater with it's puny little wires adds over two degrees to the fuel temperature anyway.
Do you have p/n's for the head and filters that have a better micron rating and proper flow rates? That are cheaper?
MIDNIGHT RIDER
Just about any company that builds filters also sells generic standard-thread filter-heads, to which a whole host of filters are available for whatever filtering need one has.
You can get single-filter units, or doubles, and even triples.
Most big trucks use a double for the fuel, with a water-separating coarser PRIMARY and a much finer SECONDARY.
These are pretty much standard, thus not so expensive.
The best water-separating filters have a solid bottom with integral, made on the filter, drain-*****; none of that two-piece open-bottom leaking crap.
Fordsandguns
Fords Rule
Eastland Tx
I'm running the wix one piece filter with the built in drain. They cost me $37.99 each to get them here. -cuss
Tractor Supply sells the filters for the fuel transfer tanks but i don't think they will flow enough to support higher rpm's. I think the ones they have in stock are rated at 10 micron.
Fordsandguns
Fords Rule
Eastland Tx
I was thinking about the oil filter type. The canister type are bigger than and wouldn't mount n the stock location I'm thinking.
I wouldn't mind putting a head on to use the goldenrod filters but I am not sure if they will flow enough. Do you have an idea what the flow rate is?
MIDNIGHT RIDER
>>> GOLDENROD <<<
If you are meaning the big clear-yellow see-thru GoldenRod sediment-bowl filter units, they are the greatest thing to happen to fuel since compression.
I cannot provide any scientific micron or flow ratings; but, I can tell you from years and miles of first-hand experience that no ordinary diesel engine is gonna feel restricted on fuel delivery when a GoldenRod is the first filter in line.
I have had one on my truck for many years and I can't begin to list all the advantages and assets.
;Sweet
Fordsandguns
Fords Rule
Eastland Tx
Well I might have to see about plumbing one in, in the future. Since they are a water separator too, wouldn't just the goldenrod itself be enough?
Fordsandguns
Fords Rule
Eastland Tx
The golden rod is for larger particles, you still need a finer filter for the rest of the small gunk.
From what I have read the goldenrod is ten micron and the stock 7.3 filters are 12 micron. Maybe I'm remembering it wrong though. :dunno
To the OP, sorry for the hijack! :angel:
