Pino2234
On my 1985 F350 there is a box on the right side of the steering column. So far in my build for my dually I had to disconnect 2 wires from it.
I attached two images. What does this box do? Do we even need it?
The first wire that gave me a problem is the blue wire in the picture that is on the gray connector pigtail. It is the ground for the horn. I wasnt getting a constant horn. It would work sometimes with the key on and not others. So I spliced into that wire and grounded it and now my horn works like it supposed to.
The other wire I am pointing to is a green one in the same gray connector pigtail. This one goes to the brake lights. I put a flatbed on my dually and hooked up new LED tail lights. The tail lights picked up a 4 volts going to the left and right turn signal wires which lit up the LEDs very dim only when I turned the key on. I wont tell you how long it took me to trace where these 4 volts came from but I disconnected this wire too and everythings works just as good as before.
I dont understand why this box is even there. Its just been giving me problems. Anyone know what its for or if we even need it?
