aaron,
Yes there are members that have used it. Some have had success, and some have made some very intersting shaped parts. Travis (argve) on the board used water/**** in the infamous Enterprise. He used to much and was "mildly" hydrolocking the engine with each compression stroke. He took it to a rally and was playing with it and went through something like 15 GALLONS of washer fluid and an hour or two. He had crazy power while he was playing with it in that time, but the end result was 8 cracked pistons and the truck being sent off to rot in a kudzu field (which is another story all together). So it can be done, just remember you can cause major damage if you use to much.......
