Water cooled exhaust
rustygold
conway Arkansas
Has anyone seen water cooled exhaust on theis 7.3? I gave seen bigger trucks have them to help EGT'S. Thought if it was out there maybe it could help us.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Lol
Water cooled exhaust doesn't help squat. Who cares if the exhaust is cold, if you're still melting pistons?
Do you mean water injection into the engine?
rustygold
conway Arkansas
Nope my 12.7 detroit has water cooled exhaust system. HD trucks have them.
According to Detroit 60 series literature, only marine engines have water cooled exhaust.
Show us pictures then.
austin92
Brazil. IN
Are you talking about misting water in to the intake to drop egts?
1983 f350 6.9 zf5 2wd srw single cab long bed. Facet duralift, optima red tops, bfg all terrains, 4" exhaust from y pipe back, autometer z series pyro, pump turned up 2 flats
Cruiseomatic
Defining Insanity
Dark side of the Sun.
Water cooled exhaust is pointless really. EGTs start in the combustion chamber, make there way into the turbo, then out the exhaust system. You want to watch the EGTs to not only avoid turbo damage, but to also avoid melting pistons or doing head damage. You could do it to avoid killing the turbo but then you're only lying to yourself when you could still destroy the pistons. IMO, Skip it. Yes heavy trucks have it. They also have heavier duty engines and are running 100% duty cycle.
Now misting water into the intake might work. Would cut down on carbon build up in theory.
cpdenton
Truck needs paint.
Conway AR
Are you talking abut circulating engine coolant through the castings, not actually into the combustion gases?
rustygold
conway Arkansas
Ok so water cooled is only good for turbo so it doesn't over heat but other then that it's pointless
So is it a water cooled turbo?
I'm interested to see what you find in the manual.
FordGuy100
Silverton, OR
New VW TSI's (gas) have the exhaust manifold integrated into the head (turbo literally bolts to the head), so they are water cooled now. My guess is it helps turbo heat soak, if you have extended high EGT's.
hce
So can i....
Glasgow MT (Official middle of nowhere)
I could see this on larger engines, that can control the heat of the piston by cooling with large amounts of oil or the use of monotherm steel pistons that can handle heat. Now given the pistons can take higher heat, the turbo is going to need protection.
SixFourShanks08
