Wastegate not activating
Mudsling
NEW YORK
Hi, I am new to this forum so excuse me if I am not in the right page. I just rebuilt the Holset HX35W turbo on my 5.9l 12 valve Cummins. When I rev the engine the wastegate arm does not move. I traced the line going into a port on top of the injection pump (some solenoid looking thing). I put my finger over the port as I rev the engine and nothing happens, there is no vacuum. Am I missing something.
DaveBen
Ukiah, Ca
Diesel engines do NOT produce vacuum. You can rev it to the redline and no vacuum. This is why there are vacuum pumps for the brakes and/or the Heater/AC. The wastegate is boost operated, as 79jasper stated.
Mudsling
NEW YORK
Ok thanks I learned something. So the tube that goes into the wastegate goes into a T and the other side goes into the intake. This T is at the end of a solenoid. How do I make this line work so that the wastegate operates? I apologize for my ignorance!
DaveBen
Ukiah, Ca
Normally you only need a hose from the intake manifold to the wastgate actuator. That simple, no T's needed. Where does the other hose off the T go to? A dash gauge for boost?
Goes to the AFC. Basically like the smoke puff eliminator.
Mudsling
NEW YORK
If you look, the hose goes to the wastegate and the small line goes to the intake. When I rev the engine nothing happens to the wastegate actuator (does not move at all) I don't have a boost gauge. This truck is bone stock.
Mudsling
NEW YORK
79Jasper, Ok I get it. So you are saying that the actuator won't move unless the truck is under load. So then the rebuilt is good. I replaced HX35 exhaust housing and wastegate, and I got the rebuild kit all from turbo lab America. I took the truck for a ride and it sounds great and runs great. Thank you so much for the information. I am so grateful for people like you that have the knowledge and are willing to share with the rest of us. Thank you.
As another tidbit, many guys with cranked up pumps actually disconnect the Wastegate and tie it closed for more boost. So long as it wasn't stuck open, you should be good to go.
Lance
