res0wc18
3ive been thinkin ....
no way, it needs to be heated first then pressure filtered. Its hard to shove it through one micron filters heated let alone gravity un heated. There is an easier way to do it.
Heres my simple simple setup.
I have and old diesel transfer tank and pump combo in my bed. I plumbed in a 10 micron primary and a one micron final filter after the pump. I simply pour my waste oil into the tank. And then take a 5500W water heater element that i hard wire to a 240 plug and wire setup then drop it in the 90 gallons or so of oil turn it on and a half hour later its boiling hot. The convection will mix the oils and burn up and steam out and water. i do this till there is no more water vapor coming out, then turn the element off.
I then take the nozzle put it in the same hole i just pour the oil in and turn the pump on. I let the pump run until the oil is so cold it wont flow any more, keeping wet rags and spray water bottles around to keep the pump cool.
This effectivly filters the oil for cheap and no mess.
