Fredrickson
I want to add another set of brake lights to the truck, but I read changes in the resistance of the brake light circuit can affect torque converter lockup.
Is the lockup issue only when a bulb is burned out or missing, or will additional bulbs also affect the circuit?
As far as a solution:
Can I tap directly into the existing tail light's wiring and add the lights in parallel?
Should I use a 12v relay to trigger the additional light?
or should I get one of those trailer light conversion kits?
Or is there another, better method I am completely overlooking?
Thoughts?
This is on a 1994 E350
Thoughts?
