Want to change your horizontal Fuel filter w/o the mess?
tgatch
Just tried this and it worked great.
Take a piece of tin foil and make a catch area under the filter along the frame rail. make sure you have a "funnel" at one end. Loosen the cap and you have a clean filter change. ;Sweet
Check the attached photo.
CHarlan
Bulverde TX
or if you use a 6mm allen wrench, and loosen the bleeder screw... when you drain that, you can remove the filter, and little runs out... We do it all the time at work.
camoman
how often should a guy be changing the fuel filter? Ford wanted $116 CDN for a new one
tgatch
JIM_C said:
Filter looks kind of RED, Tom! :eek: Just kidding.
Nope... not red. I have never even been to place that sells the red dye stuff. Not worth the risk, so I don't do it.
Tom
