BigRigTech
Diesel junky
I just finished installing a Golden Fuel WVO kit on a 1991 Dodge W250....He took it home tonight, it took some time to get my head around the plumbing and etc but it works really well...Two Hot-Fox coolant fed heaters in a 135 gallon fuel tank mounted in the bed and a trick 3 valve setup on the engine....The pump is electric, the fuel filter is 2 micron and heated as well with a wrap...It has a purge timer to flush the WVO from the system before you shut it off....I could buy all this stuff locally and build one for myself but I don't drive my truck enough to need it...Just thought I would give you guys the heads up on this kit and that in my opinion it works well.
