v-10
Looking at 2002 f-350 srw v-10 has 178,000 given oil changes have been done regularly . What kind of life are in these motors?
if you have verification of proper oil changes, you "SHOULD" be OK. biggest problem for the motor internally, is the balance shaft on the driver's side head has no cam bearings to ride on. the bearing surface is directly machined into the head. it can be repaired, but at an extreme cost.
hardbound
Prince George/Va./us
Thanks for everyone's input figure if I can get truck cheap enough it would be cost effective to rebuild things over time. Truck will not be a daily driver.
Also I have another question truck 2002 f-350 srw . What model years will the the rear end interchange with. I already know truck has a rear end issue so my opt to just change out rear rather than repair .
m2rtin
