jaluhn83
If it's just a bad switch, sure. I'd guess it's a problem with the wireless transmitter or receiver though which is most likely beyond the average owner's capabilities to troubleshoot / repair.
well that would be sweet. I believe I can find another battery, although its extremely thin, Its soldered in a housing and the batterey about is the size of a nickel and thin as a dime. The bigger problem is the grey push button on the red button has quit pushing. It does nothing when I push it.there is a small diaphram behind it and I believe its wore out possibly. Thats why I hope to find red control button.that would be the cats meow. The exhaust part worked just fine, before the button quit---RobHow about just fixing the red button box?
I am digging around for my sodering iron and I'll see if I can upload a pic.(never tried that yet!)---RobI meant maybe take the box to an electronics repair place.
Or even find a friend who's good with electronics.
Edit: Can you get me some pics of the box and button?
If just the button and battery, I'm sure I can find something to replace those.
Any numbers on the battery?
I am trying to find the install manual,but I don't recall any kind of schematics with it. It seems pretty basic operation as you say. I just push the red buttonand the flapper closed. push it again and the flapper would open. I never did use the foot pedal defeat after it wore out many moons ago.There is a red control box that has an on off switch to set operation in ready mode. The wiring under the hood is seems complicated with a whole lot of wires and relays going to the unit in the exhaust and the red box.---Rob
A pretty chatterbox female companion achieves the same effect. With the added benefit of an extra pair of eyes on the road. lolNothing like having extra lights, gauges, bells, whistles, and alarms to keep you awake while driving.
*Correction, that could be a first or 2nd gen unit*
I found a troubleshooting guide, see attached if it works.... if not I can e-mail.
I looked at my parts stash and I have a spare control box but not the button part. Unfortunately the button and control box are going to be a matched set so I don't think my box will help you any.
If you send me your box and button I can probably get it fixed, but I'd need it for a month or so. (My father is a very good electronics guy who loves fixing stuff like this, but it's not overnight)
On this generation there should actually be 4 wires (and a ground at the brake). 2 of these are required, 2 are not. The large gauge grey and smaller gauge white wires go to the solenoid and are important. These should each go to a relay. The brake is actuated by a dual coil solenoid - 1 coil closes the butterfly and pulls ~55 amps, the other holds it closed and pulls much less (~2 amps). Hence the large and small wires.
3rd gen units (wired pushbutton instead of remote and no LEDs / rocker switch on the main control box) have a relay on the grey wire for pull in and the white wire connected directly to the control box.
On 1st/2nd gen units the other 2 small wires (blue/orange) connect to a pressure switch on the brake that lights an LED on the main controller indicating a downshift is required for optimal braking. These are not critical for operation.
So to operate the brake, when you push the small button the controller energizes the pull in relay for ~2 seconds while applying power to the hold coil. Power in continued to the hold coil until the button is pushed again or the throttle switch is activated indicating you pushed down on the gas petal. When the throttle switch is activated, the unit goes into a standby mode indicated by a blinking red LED on the push button and will close the brake again once you return to idle.
2nd and 3rd gen units will also automatically cycle the butterfly twice on startup to keep it free of carbon.
And no, attachment didn't go thru for me either. I was just going by his explanation of the wiring - it's good enough for me to visualize it, that's all I needed.
Minor details on the co-pilot, minor details. Besides, you gotta have something to look at while running along them semi-deserted interstates in the middle of night, else it gets real boring real quick.Only problem is that the driver's eye are *not* on the road.....
Looks like the PDF files are too big to attach, but I can e-mail them if anyone wants.
The low pressure light is pretty useless IMHO - it's pretty easy to feel that you have less braking and you already know that lower rpm = less braking. I also seem to recall that there were frequent problems with the sensor clogging.
LCAM, that would probably work. Just make sure not to leave the pull in coil on too long - I'm sure it'll burn out real quick if you go too long.
If you'd like, you can E-mail them to me and I can put them up on my webspace and post a link here, so anyone who wants can take a look without you having to send a bunch of E-mailsLooks like the PDF files are too big to attach, but I can e-mail them if anyone wants.
