NapaBavarian
Dually driver 6.9
my exhaust run from the turbo outlet is a gentle 90 deg down and goes outside the frame so I don't squish the pipe. you haven't seen a down pipe get run over by a forklift until you seen a GM one.
This whole deal should be interesting, technically the Cherokee is a full size truck, but the engine compartment is tight, and the space between the transfer case and frame might be just over 2". I've always called the AMC V8 a mid block, bigger than an SBC, smaller than a big block, but it's a tight fit with all the accessories, big block size is doable, but takes a giant shoehorn!
