unexplainable issues.
travisjulian
Just scraped this of 3 of 8 injectors. What is it?
travisjulian
Round tip and copper washer
Sent from my SAMSUNG-SM-N900A using Tapatalk
travisjulian
Im ordering moose misters.im sure they were on there way out.
travisjulian
Anyone tryed having hogh pressure lines made. Been thinking about it something more flexible and easier to repair if needed.
Do moose mister require headstuds or just the combo of pump and injectors.
Depends on what pump and turbo you want to pair them up with.
As for your smooge on the brush, I would expect that to be rust, probably washed down with some kind of fuel or oil.
travisjulian
Stock pump banks turbo. I should be calling today for the moose misters after my wife shipps old injectors and sends me tracking number.
Brake fluid becomes corrosive and Acidic over time .. brass and aluminum would'nt last at all ...
Copper work hardens over time and becomes brittle. Not something you want in a brake system either for things like the lines and fittings. Banjo bolt seals sure, why not.
travisjulian
Moose misters ordered
travisjulian
Easiest way to check compression. Take injectors out put plast bag in injector holes rotate engine and you will see the bags go downa and up lol
4x4manonbroke
Diesel Master
Tacoma Washington USA
Some rust is not really uncommon , A bit of fuel, and some moisture, not a big deal, clean it out real good , if you can get a small wire brush - and some brake clean ..
radeon1314
