U Joint Size? At Part Store Waiting!
NeverHave-I-Ether
Texas
Howdy!
1993 F250 7.3 IDI ZF5 4X4
Getting u joints for my truck. I have two options. 1.188 or 1.063?? Which one do I get? Really don't want to buy both and bring a set back later, don't have the money for that.
Never-Have-I-Ether
If I remember correctly, it's the bigger one. Non diesel F250s use the smaller ones. Ran into a similar issue, bought u joints, just for a f250 they sold me smaller ones by mistake.
NeverHave-I-Ether
Texas
Gotcha, I was thinking the same. Just grabbed those! I drive a big ol' diesel, ofc I get the biggest part:Thumbs Up
Definitely not gonna blame you if it doesn't work:joker:
Here is the confusing part! They also have a u joint that is 1.063 AND 1.188. Good grief, why can't it be simple?:idiot:
Never-Have-I-Ether
NeverHave-I-Ether
Texas
Ok, now I'm getting started! Want this to be as easy as possible. Do I have to pull the shaft out of the tcase? Or can I leave it on and while replacing the joint?
NeverHave-I-Ether
Texas
Got home from the parts store. It was a horrible drive back.
Looksy what I found when I got underneath! Talk about close! Hope the driveshaft ain't damaged.
Never-Have-I-Ether
NeverHave-I-Ether
Texas
:shoot::rotflmao
305k+ miles. Finally came to an end.
RIP
Never-Have-I-Ether
Hot dog man! So was the one you got the correct size?
You got lucky on the u-joint size thing. I have a 1989 f250 and it was originally diesel with a c6. I bought a 1989 f250 diesel wrecked donor for a zf 5 speed swap. The c6 truck had the smaller u-joints. The zf truck had the larger u-joints and the driveshaft was twice as heavy as the one out of the c6 truck. I ended up swapping the yokes on the rearends and using the large u-joint heavier shaft in my truck when the zf went in place. Both trucks were f250hd's with the diesel engine.
NeverHave-I-Ether
Texas
Well Nero, the 1.188 u joint (biggest they have) is too loose. I'm wondering if the yoke is bad? It fits snug on the driveshaft.
Never-Have-I-Ether
ROCK HARVEY
Dayton OH
The 1.188 is the size that fit mine. Mine were super tight and difficult to press in/out. I think previous owners used the “big hammer” method and deformed the yoke on mine.
I'd MIC them out, cause my U joints for both mine and my dad's ZF had to be pressed in on both the tcase yoke and the driveline side.
With how one u joint cap was worn all the way through, could have some damage to it causing the hole to oblong.
NeverHave-I-Ether
Texas
They are definitely 1.188.
I used the press to get them on the driveshaft. On the tail yoke to the tcase, it is very loose per my video. I bought a third 1.063 u joint just in case and to compare. It's definitely smaller by 1/8th of an inch. It's just the tcase yoke that's super loose.
Very strange.
Never-Have-I-Ether
IDIDIDIhoDhoDhoDO
Earth
The caps off the old U joint didn't seem loose in the yoke in the first video you posted. Get a pair of calipers and measure what's left of the old caps, the new caps, and the yoke bore. Get some numbers.
NeverHave-I-Ether
Texas
I finished last night at 3 am. I had the attitude of it works it works. Clips hold the u joint on the transfer case yoke. Everything was pressed into place on the driveshaft. Only issue was the yoke, which I will need to order a new one eventually. The old caps were very snug, not sure why they are not now but like I said, in the driveshaft they fit very tight.
The truck drives amazingly smooth now.
That last u joint cracks me up how bad it was. Goodness!
Never-Have-I-Ether
Nanohawk
