rthomas
is there a switch somewhere for this? this truck spent some time in BC and im sure that why there on, as far as i know in '97 DTRL wernt standard.
betcha it's on the frontside of the core support on the driver's side.thanks guys- where is it located? i looked around the core support and i dont think its there.
If you only unplug it , your hi beam indicator on the dash will not light, nor will the emergency brake light indicator. Both of those circuits run through the module and the plug shorts out the wires to make them work normally.
