Turbo seal kit and water pump
94turbocrewcab-lb
Mid coast Maine
Well I just got the rear main seal done last night. I might as well change out the water pump.
The Napa one I can have tomorrow for $66 not sure the brand maybe try-flo
On rock auto I can get an AC Delhi for $66 bucks..what do you guys think? They also have one for $33 but never heard of that brand.
Also I might as well pull the turbo and replace the mounting seals. I tried calling the russrepair guy bit no phone number to be seen. Can someone link me to the correct kit to get from them? I have a factory turbo and it’s not an ats.
All the bearings and seals made in china, no difference.
And I have a website no phone number.
About the water pump, I replaced one on my dad's rig recently, I had to file the bolt hole boss that goes right below the IP housing, as the casting was so thick, that it was interfering with the IP housing.
94turbocrewcab-lb
Mid coast Maine
Hey type4 I just prefer to talk to people. But yep I just found the factory install kit.
So regarding the water pump
..should I just buy the cheapest one? Or just go with Napa?
The one I used was Napa, sorry should have specified. Have had zero issues with it so far.
bigrick460
ahoskie N.C.
Make sure you put the right bolts back in the right hole. Some bolts are longer and misplacing them can cause engine damage.
Big Bart
Tow&Slow
Newport Beach, CA
Also use sealant on the ones that go all the way through to the crankcase or they may leak coolant into your crankcase and mix with the oil.
720Diesel
