diezelcrazee
I got interested in helping my truck breath better and so I read up on doing the 3" turbo outlet elbow mod in the following link (and others):
http://www.oilburners.net/forums/showthread.php?47739-Turbo-exhaust-elbow-modification
Also to help with breathing, some owners have installed a 4" exhaust system and downpipe for an OBS Powerstroke, with slight mods to the downpipe.
All this well serve to benefit any future performance mods, so I decided to go with it, and I got the parts together and yesterday started the project by taking out the old exhaust and downpipe.
I had today off, so next I started working on the 5 exhaust outlet housing bolts.
Whoever it was that said those 5 elbow bolts are a pain was sure right!!! I finally gave up and pulled the turbo.....Like under the hood all day crammed in the engine compartment, pullin the turbo.
I don't know if its possible to pull an outlet elbow on the truck if it hasn't ever been off before like mine. (apparantly) Before I pulled it, I managed to get 2 of the 5 bolts out, then proceeded to round off the head of the one by the wastegate arm...
So I spent most of the day pulling the turbo so I could get to the other 3 bolts. Hadn't even tried on the one under the elbow. Sure was nice with the unit in the vise on the workbench. Impact driver made short work out of 2 more bolts, then I was able to break the under elbow one loose with a box wrench.
The 3/8" studs n nuts that hold the turbo to the up pipe? Well thats another story....I managed to get all 4 of 'em finally, but it wasn't easy.
So I chased the mounting stud threads with a die and cleaned the housing holes with a tap, and now I have the turbo back on the truck. Also I cut off the funneled down end of the outlet elbow, so next is to weld the short piece of 3" pipe and the v-band flange on and start putting the elbow back on.
Then I can start on the exhaust install....
Sorry no pics, but I guess there have already been lots of pics posted of this mod.
More later...
More later...
