George_7.3IDI
I've got a hypermax non wastegated turbo that I recently installed on my truck. I just took it apart yesterday because I have an oil leak problem and it seems to be coming from the turbo. It looks like it was leaking at the seam where the turbine housing and turbine wheel go together. I also found that some of the bolts holding the flat curved metal bars in place to keep the turbine housing connected to the rest of the turbo unit where loose.
So the first thing I was wondering is it even possible for oil to be leaking from the seam where the turbine housing and turbine wheel go together?
When I took the turbine housing off and starting from the end of the hot side turbo shaft there is the turbine wheel and then what looks like a small cylinder with one end cut off and a lip on that end that sits in the recess in the turbine housing. I was able to move that cylinder piece up and down on the shaft slightly but I can also move it around on the shaft. Is this something that I should be concerned about?
Also this is on the '92 in my signature.
Thanks for any help
George
Thanks for any help
George
