The front tank does not need to be dropped to remove the sending unit. Just remove the electrical line and the two fuel lines and then hit the lock ring loose and its out. You have pelnty of room to work on it under the truck because its set on the angle side of the tank. Just get under there and look at it before you try to drop the tank.
