GREASE FIRE
about a month or two ago i noticed my truck was taking more cranking than usual to start, but it always would go after two good cranks. Once it started, even if i let it run for just a few seconds, i could shut it off for a few minutes and then it would start right up. Once fully or even partly warmed up it starts instantly.
the batteries and starter are like new; it is getting power to the solenoid at the pump (10 or 12 volts, i forget which at the moment) and i also put a voltage tester at one of the glow wires and turned the key on and that was getting about 10 volts i think)
i used a simply continuity tester (the kind that looks like a screw driver and lights up) on all glow plugs and they all checked out as normal (they are Beru's).
there is fuel coming to the pump.
it started yesterday with some cranking but ran fine right until i shut it down.
now, as far as the glow plugs - is there any chance they could be checking out fine with the continuity tester but still not working properly (like not heating up enough)? i tried cycling them several times in a row just now and that did not do it.
Could anyone offer some suggestions? i really need to get this truck going
thanks!
Paul
thanks!
Paul
