This the normal tranny function. The coast clutch is applied in third (OD Off). The coast clutch will release in fourth allowing the tranny to coast.
That's what's sounds like could be broke.
The coast clutch would also be applied in any manual low gear (2 or 1). I take it engine braking in second or first does work then?
It doesn't work, top of manual 2nd if i let off it makes the medal noise.
Ouch, sounds like its somehere in there then. Coast clutch or maybe a one way clutch (sprag).
Most likely the coast clutch snap ring popped out of its groove. Very common problem with this transmission. The fix is a special snap ring that gets fitted into the drum.
If the vehicle doesn't move, the tranny will need to be rebuilt. The amount of carnage plus any updates will dictate the price of the rebuild.
Pull it and open it up. I would rebuild it. My opinion will be biased because I'm anti ZF.![]()
It's the most updated trans, it's from a '97. I'm letting my friend rebuild it, has his own repair shop and does trans work daily.
Figure if he can build a GM 200R4 trans to hold up behind low 11 second buicks, he shouldn't have a problem redoing a E4OD.![]()
He should have no problems with the E4OD. It's like a C6 with an extra gear and a solenoid pack.![]()
Mike I kid you not, I winced when I heard that ratcheting sound. OUCH!![]()
