Not sure in your case because of the ranger spacing the tranny back but, when I swapped in the ZF5 using the linkage from the BW1356 going to the existing BW1345, I had to make a shorter link between the two. Just used a piece of 1/8" x 1" steel flat bar, cut 2 holes inn the ends, and transferred the plastic bushings to the new link. So in the case that you need a longer one, they are easily made.
