Trans temp question.
FULL FORCE
Cleveland,Ohio
I just put my trans temp gauge in, what is "normal" so far all I got it up to was 150 is that normal for no load? what is the hottest that is safe?
jharvey
Shutter Bug
Georgia
90-100 degress above ambient temp is about normal, in the summer mine would set right at 195.
John
Mastertech
Car Doc
Houston
The hottest I have ever seen no load in the HOT Houston summer running the truck hard in traffic is 170*-175*.
96_Bear
Shane
Centerburg,OH
Freeway cruising mine shows 165 to 180. In town with lots of stop and go I will hit 195 easy when the temp is 85+
96_Bear
Shane
Centerburg,OH
Freeway cruising mine shows 165 to 180. In town with lots of stop and go I will hit 195 easy when the temp is 85+. Is your probe in the pan or in the 1/8" port on the side of the trans?
FULL FORCE
Cleveland,Ohio
I was told to put it in the trans plug just above the pan, when I do a fliud service I will weld a bung in the pan and put it there.
Mastertech
Car Doc
Houston
Mine is in the port on the side of the trans.
SixFourShanks08
