Some here may know that Ive mentioned my E4 has been on borrowed time. Well it very recently has been progressing a little faster.
However, this is not a thread to debate a diagnosis or repair, moreso which direction to go in for replacing. Money is extremely tight so the most inexpensive method is required.
Now onto the nitty gritty. Finding a used E4 for a 7.3 is a bear around here and I really dont like the idea of putting another timebomb back in the truck. Id love to be able to get the updataed Ford replacement but $2k is out of the question. I like the E4 when it works and would like to keep the factory look of things on the inside but money is really pushing me away from this option.
Guys that have ACTUALLY DONE A ZF5 SWAP your opions/advice will be greatly appreciated right about now. These used are reasonably priced around here and would be plenty beefy. Theyre not that plentiful but they are out there. Talked to a guy earlier today off CL that had just let one go from a '94 F450 for $500 complete trans/clutch/pedal assembly. What I need to know is how difficult the swap is and EVERYTHING I would need partswise. What would I be looking at total cost aside from the trans/clutch/pedals? Any fabbing thats required aside from cutting the hole for the shifter?? Anything else I would need to know about this swap?? Will any ZF5 work? The guy off CL said theyre all the same regardless of whether you have a transfer case or not.
Lastly Im debating a C6. These for a 7.3 are scarce around here to say the least. Also, the ONLY WAY this would happen for me is with a aux overdrive. With my 4.10s I wouldnt be able to go over 50 without turning the heck out of the engine. And Im not swapping gears. The 4.10s will allow me to go up a tire size down the road and still be able to tow. Plus swapping gears is more money so right now its out of the question. So, what am I looking at costwise for swapping a C6/GV (or something of the like) in the truck? Fabbing and differences?? Difficulty??
Sorry for the novel, any help is greatly appreciated.
Jon
Jon
