'94IDITurbo7.3
HAMMER DOWN!
The vehicle is the one in my sig.
Last fall my OD light started flashing so i took it to the guy that rebuilt the tranny in my dads truck. He replaced the MLPS, didn't solve problem. then checked the TPS said it was way off, he reset it and then it was shifting nice and smooth around 2500-2700 rpm. drive it for a few days OD light comes back. he then replaced the tach sensor. that fixed it until the first of this year. then the OD light again i called him he said to check the tranny fluid. i did and it didn't even show on the dip stick. so i topped it off. Ever since christmas my shiftes 1-2-3-4 have been getting firmer and later around 3100-3200 rpm. i checked the TPS and it was right were he set it .8 idle - 3.8 WOT. tranny guy also checked and cleaned the elec plug on the pass side of tranny.
What could be causing my shift points to change like that?
also when i shift it into drive or reverse the engagement is delayed about 2 sec then it has a very firm engagement.
Thanks
Thanks
