Tranny questions....
MARQ2277
caldwell, idaho
What wattage are you using. I still have to replace mine, because the poteniometer I am using is only 3 watts, and it gets too hot, even with a heat sink. I (when I get paid), I will probably get either a 10 or 25 watt one.
MARQ2277
caldwell, idaho
Darn, I didn't answer your question, well the potentiometer I am using is a 25 ohm at 3 watt, and I have it adjusted at about half. So it must be close to 10-12 ohms at 3 watts (which is too small).
It does shift just a bit firm, but when I replace it, I am hoping to adjust it in better.
Marq
