ericboutin
I'm about to tackle my issues with tranny temps...here's what I want to do but I need some info first. I want to come out of the hot line on the tranny and put a Perma Cool trans filter then go into the stock OEM cooler in bottom of rad (this was disconnected long ago by PO) then go into a cooler mounted on front of rad then go back to the tranny. Unrelated I'm also going to install a pusher fan while I've got the grill off to help with A/C issues etc.
Here's my questions:
1. There are two lines coming off the tranny both on the passenger side...one is located in the back and one closer towards the front of the tranny (front of truck) Which of these lines is the hot and which is the return line?
2. Where can a Perma Cool Trans filter be bought? Advance? Napa? And I'm thinking that I would like to mount this closer to the front of the truck (where all the lines are gonna need to be spliced anyway) as long as I put it before the OEM cooler would that be ok?
3. Like I said the stock cooler was disconnected - how do I go about flushing those two ports? With water? And which port is which or does it matter? There is one on the pass side and one on the driver's side on the bottom of the rad.
4. The existing cooler (and right now only cooler) that is there is kinda small...can I buy a bigger cooler and place it in front of the one already there? Basically going from filter to stock OEM cooler to existing air cooler to another cooler then back to the tranny?
Sorry for the long post but I need to go ahead and dive into this before a big trip towing the TT next month.
