Silver Burner
Burnin' Oil&Rubber
So I pulled out my trailer yesterday to start getting it ready for Memorial Day and all seemed good for about 10 minutes. I had the 7-pin plugged in and I had moved the trailer back into my driveway when I noticed my Draw-Tite controller flashing OD at me. So I shut the truck off, got out, and went to unplug the 7-pin. It had gotten really hot, which sucked. Anyhow, I discovered that the wire feeding the signal to the trailer brakes had melted all the way down the frame of the truck. Which sucked... So I replaced it. Now I don't have an overload anymore, but my controller doesn't seem to be working properly. Has anyone ever seen a controller (when you step on the brakes with the trailer attached) flicker between 0.0 and 0.5 and not ever go up? When I hit the manual button, the display goes really dim and flickers but shows a proper value (normally mine will go up to about 3.0. I can't find in any of the troubleshooting questions anyone having the same issue. Is my controller fried from the overload? I'm going to test my trailer brakes this morning manually but they appear to be intact. I'm about 99% sure the short made it to the 7-pin and stopped because there was too much resistance on the trailer and the 12V had a much easier path to the frame of the truck. Thanks in advance for any input guys.
