Dualie
pyromaniac at large
OK seems our new to us 99 trail king beaver tail's ABS light comes on when backing up and applying the brakes. I don't know if this is a meritor or a wabco system as any identifying tags were covered up in a Sherman Williams rebuild before it came to us. It is a low profile trailer that runs the 17.5" tires and wheels.
where can I get info on working and servicing this system. Its a real pain in the butt to work on the front axle of the trailer this thing sits way to low to the damn ground, rear is easy just flip the tail up .
Also what brand of air dryer filter do you recommend? Turns out the after a little investigating the truck has an air dryer it just got covered over in the repaint too. Its the type that has a spin on filter mounted up side down.
