Doc
I went out to fire up the truck to go home from work. When I first turned the key everything seemed fine, wiat to start light came on, radio worked, all the dash lights, etc. When I turned the key to fire it up, everything went completely dead. I mean completely dead. I can't get any power to anything. I even tried bumping the starter directly from the solenoid and got nothing.
I checked all the fuses under the dash and under the hood and they're all fine. I don't see any loose connections under the dash and I don't smell anything that would indicate an electrical part went bad.
I was having some trouble with the column shifter, but I tightened up the bolts to the cable bracket and everything worked fine.
Suggestions, ideas, any help would be great. I don't want to have to call a tow truck.
