Macrobb
Be aware that if you are using a worn IP, the timing is a reference at best. As the IP wears, the timing gets out of whack, and you should definitely adjust it back and forth and see what it 'likes' in terms of best power from whatever your timing would otherwise be set to.
What makes most power will end up being efficient as well. Take it out for a spin, adjust and drive again, until you've dialed it in.
