Took the Glow Plug swap plunge
smokinpipes
Navistar Nut
Kalamazoo Michigan
...and so the story begins. Over the weekend, I went to use slim to look at a truck; and she started hard, smoked, missed and bucked for well near a minute. Just like her old cold blooded self. The day progressed without incident, which I felt was a nice birthday present, get out my IDI for a nice Sunday cruise.
On Monday, I was planning on moving her to unload the bed tank of Diesel to haul some soy oil from work... and the glow plug lamp, acted, um, funny. On for 2 seconds, and off... it was about 30 degrees out... but only was cycling on the afterglow cycle. Well, I suppose it's time to ditch the old bi-metal controller and get with the 90's and upgrade to the Solid State system.
I had a couple solid state controllers and harnesses, and a set of Beru glows from a few trucks I'd salvaged. Let's use one.
I scavenged for some how-to's and wiring diagrams, and eventually found everything I needed; but nothing was concise on a step by step.. how to adapt wiring harnesses, etc. etc. So, I plan on publishing my trials and tribunes in a tech article style for others to be able to reference in the future.
The end result, ripped nearly everything out of my engine compartment (electrically), I sorted out the rats nest of wiring, and removed stuff I didn't need (i.e. the factory charging wires, a junction used to repair two burnt fuse-able links due to a faulty alternator), learned that to replace the engine wire loom don't use 3/4" size, how the 6.9L engine side harness is wired, how to smoke a solid state controller, 1/4" air hose isn't a good vacuum hose replacement, where to buy quality bullet style wire connectors that fit the bullet glow plugs (properly); that the hollow cast aluminum glow plug controller is a royal pain to remove without proper tools (it's still in the engine), and that something of this nature is best to be done on a fair weather day, or in a shop and not outside in the middle of February.
I also did not mount the controller on the engine because of the old controller still stuck in place, and two I did a slight 'mod' to use the glow plug light WITHOUT having to tear my dash apart to get it to illuminate, WITH the controllers glow plug light wire. I used a relay :D Since the glow plug light on the Solid State GPC is grounded by the controller, I used that to ground out the switch coil of the relay, and then tied the glow plug lamp wire to the switched side of the contacts, then connected the remaining two contacts to the "hot in run" terminal of the GPC.
Other than wanting to do over the engine harness looming, and finish some off the electric fan control wiring (clean-up); I am very happy with it. The important part however, she started right up without missing a beat.
So far, I am very impressed -
Brad S.
NW IA
Vacuum canister, right next to the GP controller.:dunno:dunno
Had to look twice too, good call Al.
smokinpipes
Navistar Nut
Kalamazoo Michigan
W T F......is that....
THAT is WAY better than what it was...LOL - Like I said, I still have some stragglers to tend to, and add some 1/4" looming to to give the appearance of organization.
I figured it would be okay (it is not actually touching; about 1/2" space from the side where the terminal is) considering the plastic guard that covers the thermal resistor/shunt is much closer than the vacuum ball.
From as much stuff as I pulled out of there, it is still pretty tight. I am going to either remove or relocate the vacuum loss warning pod (mine does still function surprisingly); and the vacuum pod will get moved, just not sure where yet. I think I may try and cram it under the battery tray by the wheel well.
BUT, as I said, all of this is a fair weather project; the conversion was because done out of necessity.
SparkandFire
We're drinking beer
Aptos, CA
Cut the GREEN wire! No wait !!! The RED one... Damn I don't know.. Clock is running out.
boom!
:D
smokinpipes
Navistar Nut
Kalamazoo Michigan
boom!
:D
LMAO!!! You have no idea how many times I checked to make sure I had the correct wire.
I did this but used the 7.3 harness off of eBay.
http://www.oilburners.net/forums/showthread.php?61532-Slant-nose-glow-plug-upgrade!
These tells how to get your glow plug light to work and show them cycle
I was going to adapt a 7.3L harness, then didn't want to cut and splice engine harnesses to get it to work, so I worked with a 6.9L harness I had laying around. My engine goal was I wanted to keep the original plug functional, and didn't want to splice a bunch of wires either.
I saw how a couple others got their glow plug lamps working, but I didn't want to cut and splice anything, nor did I feel like ripping my dash apart at 10PM. So I used a relay to give the glow plug lamp power.
One thing you will find is when I 'tinker', I tend to keep what ever I am doing or modifying modular. Simply put, I try to not modify anything on the vehicle directly; so if it doesn't work, it is nothing to undo, or as the case has been in the past, I can duplicate and have a 'kit' to where all that is needed is to plug it in; because I usually do this to all my trucks.
lewisstevey7
