w123suv
I am getting ready to convert to electric fuel pump and… I am using a raptor pump which I know is overkill but it has a lifetime warranty and I already own it so thought I might as well use it. On a previous IDI I had been using it without a regulator and all the way turned down it still put out 10 PSI which caused loud idle and maybe had my timing out of whack? (I just recently learned about this)
On the new idi I have a regulator with return that I plan on setting at 5-7 psi. I would like to mount the regulator under the hood (this is a van) and tee the return into the overflow line off the filter. My question (finally) is: will I be returning to much fuel at that point for the low pressure lines around the injectors to handle? The pump is the 150 GPH model. I don't know if it moves less when you turn it down or not.
