UPDATE
After getting it fired up yesterday and letting it run for over an hour it would start once shut off. 2 hours after last shut off it would not start, i only tried 2 starter cycles but that was expected. I am going to thoroughly tighten all of the fuel lines as suggested a million times on here and hope to get it fixed today. I do have a small relay that sits to the left of the IP right below the fuel filter. I have no idea what it is for. The top of it is swollen which tells me it has suffered from heat or shorting out. I cannot seem to find one on Oreillys indicating what it could be. My glow plugs are still not functioning - it is clicking throughout the full cycle. New plugs (tested for resistance by an associate) new module/solenoid. Could this relay mentioned be a culprit??
other issues hoping to fix soon:
- Power steering pump not working at all, was dry, when we added fluid it just poured out of the bottom. I cannot see the leak because my belt driven hydraulic pump is mounted above it :-( could this be a line issue? The only way for me to access it is to figure out how to HOLD the Hydro pump up and out of the way, may use a small ratchet strap.
- Trans had not a fking drop of fluid .... smh. i should of checked ALL fluid levels before letting it run so long, my mistake, i let excitement cloud my judgement. Getting a case today to have on hand at my shop.
- Brakes were super hard. I would imagine from it sitting so long everything, caliper pistons and fluid is stiff. Going to bleed out all of the lines. I am not sure if there is a CORRECT way to drain brake lines, i know how to properly bleed them just never had to refresh the lines, OPEN FOR SUGGESTIONS!!! Thanks in advance!
- I have a guy coming with a diesel timing light so he says, told him im not paying a dime if its not the correct light, luckily, i graduated from 7.3idi youtube university last Thursday night with a bachelors in setting timing on a 7.3
- I need a passenger side headlight, the one on it, the top mounting brackets are broke on the left and right side. I would not mind putting money in a forum members pocket before ordering one elsewhere. call me if you have one 706-617-0075
- Hydraulic system is slow and my levers are so worn out they are not actuating correctly. I dont know a dam thing about most of this and dont have the capital from my business to just get it repaired at a FULL SERVICE shop that works on these systems. All suggestions are welcome guys!
- Something is draining my batteries. QUESTION are these engines in general known for a specific wire shorting out somewhere (i know some older models are, not ford specific ) that could be causing the draining. I have checked radio and the more simpler things. Underneath i do have some wires that look like a cluster FWORD right behind the cab below my bedlocks that are exposed, i will try and follow them and see what i come up with.
- Install LED brakelights. IF anyone sells them on here shoot me a pm and ill see if what you have will work.
- Paint the bed rails probably industrial black
- Paint the cab our new AutoTech Lock and Tow colors.
