Brakes are NFG because pw st pump aint working. Your brakes are hydroboost and require fluid pressure from power steering pump to function
Since yer a youtube tech check out rebuilding hydralic controls...for the deck and stinger n winch
Did you replace the olives in the fuel system when you did return lines n such? If not those could be part of izsue
Get a wrench and socket and dind out if glow plugs come out and what brand. If not beru get 8 new beru. Install em and work back fro gp to co troler to rdlay and so on.
2 x 10gua yellow wires on pass side fender that feed gp relay often eff up at plug causing problems.
As said pick am end and work to other end so I like to start with gp and work ba k to battery myself. Rplace and repair as needed.
Ps pump could be a bad return lkne fitting cracked housing...bad o ring...get a good light and lay under find the return line from ps gear box...see if connected? If so have son add fluid watch for leak.
O ring for reservior is simple to change once u get hyd pump out of way.
Remove pressure line and fitting...carfukl not lose plunger and spring...remove w magnet...carefully twist plastic reservior and remove. O ring is obvious ...replace and reverse order to assemble.
Good luck
Good luck
