Michael Fowler
Sometime this Spring, I hope to get a new IP and injectors ( hopefully from Mel). Any help/experience in timing it "by ear" until I can get up to Mel's garage and have it Properly timed.?
Snapping the throttle can help you judge also. Response should be crisp. If it lags, then you are probably too retarded. With a properly timed pump, a cold engine should sound so rattly that you really don't want to drive it until it warms up.
Listen for the sound.. That sound every prius driver calls a noise....
It's a sound that wll make Prius drivers cringe.
